Trixx1992
So I'm quite a noob at overclocking.
I've gotten my 2500k @ 4290.8 [43x] MHz just by using the multiplier in the ASRock UEFI.
On full load it runs @ 1.304V and temperatures are stable around 50-54°c spreadout over all 4 cores.
If I try to go higher [44-46x] my computer won't enter windows & I just get a black screen with a flickering "-" in the upper left corner: reset > multiplier x43 > boots up.
So I'm confused at what else I should change, everything is on auto, PLL overvoltage & speedstep enabled.
This is my first time overclocking & I'd first like to check with you guys, so I do everything correctly. Any advice?
Screenshot
Screenshot
