i3 + gt 740 or amd a10 + r7 240
Rob_the_scot
Im building a small itx pc using the silverstone ml05 for gog.com games as well as the odd more advance game.
the options i have is the i3 and the Gainward GeForce GT 740 (half height and 2gb)
or the amd a10 7800 and the r7 240 (I have a few games that will benefit from the crossfire)
I cant find much info on the gt 740 only the mobile version in laptops.
As I said no demanding games
If you can get either CPU with a 750TI you'll be doing your self a big favor as the 740 and 240 are both about as good price to performance as a 780 iirc.
I would wait on pricing of the AMD Athlon II 860K, it should be cheaper than the A10-7800, and overclock. Then add a 260X or a 750Ti.
I can only really recommend crossfire GPUs unless they are high end.
Or you could go for a Pentium Anniversary as a CPU.
case can only take half height single slot gpus
Sorry guys stated above case can only take half height single gpus.
I have a main gaming pc this one is mostly for older games
Is it single slot AND Half height? If it's just one of these 2 you can probably find a half height 750 anf I know that there is single slot 750's.
EDIT: Here you go :)
http://www.amazon.co.uk/KFA2-75IGH8HX9KXZ-GeForce-PCI-Express-Graphics/dp/B00IKF9F6C/ref=sr_1_28?ie=UTF8&qid=1407065958&sr=8-28&keywords=geforce+750
Might not fit dude even width is an issue the card that can fit is this
http://www.scan.co.uk/products/2gb-...z-gddr3-gpu-993mhz-384-cores-d-sub-dvi-d-hdmi
