FarFarAway
http://www.coloryourprofyle.com/phade/alt.html
ALT-0128 € ALT-0129 � ALT-0130 ‚
ALT-0131 ƒ ALT-0132 „ ALT-0133 …
ALT-0134 † ALT-0135 ‡ ALT-0136 ˆ
ALT-0137 ‰ ALT-0138 Š ALT-0139 ‹
ALT-0140 Œ ALT-0141 � ALT-0142 Ž
ALT-0143 � ALT-0144 � ALT-0145 ‘
ALT-0146 ’ ALT-0147 “ ALT-0148 ”
ALT-0149 • ALT-0150 – ALT-0151 —
ALT-0152 ˜ ALT-0153 ™ ALT-0154 š
ALT-0155 › ALT-0156 œ ALT-0157 �
ALT-0158 ž ALT-0159 Ÿ ALT-0160
ALT-0161 ¡ ALT-0162 ¢ ALT-0163 £
ALT-0164 ¤ ALT-0165 ¥ ALT-0166 ¦
ALT-0167 § ALT-0168 ¨ ALT-0169 ©
ALT-0170 ª ALT-0171 « ALT-0172 ¬
ALT-0173 * ALT-0174 ® ALT-0175 ¯
ALT-0176 ° ALT-0177 ± ALT-0178 ²
ALT-0179 ³ ALT-0180 ´ ALT-0181 µ
ALT-0182 ¶ ALT-0183 · ALT-0184 ¸
ALT-0185 ¹ ALT-0186 º ALT-0187 »
ALT-0188 ¼ ALT-0189 ½ ALT-0190 ¾
ALT-0191 ¿ ALT-0192 À ALT-0193 Á
ALT-0194 Â ALT-0195 Ã ALT-0196 Ä
ALT-0197 Å ALT-0198 Æ ALT-0199 Ç
ALT-0200 È ALT-0201 É ALT-0202 Ê
ALT-0203 Ë ALT-0204 Ì ALT-0205 Í
ALT-0206 Î ALT-0207 Ï ALT-0208 Ð
ALT-0209 Ñ ALT-0210 Ò ALT-0211 Ó
ALT-0212 Ô ALT-0213 Õ ALT-0214 Ö
ALT-0215 × ALT-0216 Ø ALT-0217 Ù
ALT-0218 Ú ALT-0219 Û ALT-0220 Ü
ALT-0221 Ý ALT-0222 Þ ALT-0223 ß
ALT-0224 à ALT-0225 á ALT-0226 â
ALT-0227 ã ALT-0228 ä ALT-0229 å
ALT-0230 æ ALT-0231 e ALT-0232 è
ALT-0233 é ALT-0234 ê ALT-0235 ë
ALT-0236 ì ALT-0237 í ALT-0238 î
ALT-0239 ï ALT-0240 ð ALT-0241 ñ
ALT-0242 ò ALT-0243 ó ALT-0244 ô
ALT-0245 õ ALT-0246 ö ALT-0247 ÷
ALT-0248 ø ALT-0249 ù ALT-0250 ú
ALT-0251 û ALT-0252 ü ALT-0253 ý
ALT-0254 þ ALT-0255 ÿ
ALT Codes are special characters such as ¿ © « ¤. Because your keyboard dosn't have all the keys it needs, you use the ALT key and your number pad. Don't use your the numbers on top, this only works with keypad off the the right, and make sure "NUM LOCK" is on.
