yup increasing fsb is the only way.
but higher speed means more heat which will put more strain on your cooling solution so whatch the temp.
also higher fsb means higher memory speed if you run fsb:dram 1:1 so the memory might not be up to it and running it out of sync isnt a good idea from what i read.
tomshardware have found its roughly a 15% performance drop by running fsb and memory out of sync.
