First of all I recommend that you have ATI Tool .23 installed.
Load up ATI Tool.
Select settings button (bottom right), this will bring up a new window.
On the drop down box select startup.
Select: "Every time ATI Tool is launched, load profile", this will then allow you to enter the name of your profile in the box below.
Select: "Load on windows start-up via" (you can choose either of the 3 options in the box below it)
You can also select the box at the bottom (When loaded via windows startup, exit after loading above profile)
Hope this helps.
Load up ATI Tool.
Hope this helps.
