how much heat and for how long will kill a procesor?
bloodthirst
i was just wandering how high do temps have to be to kill a CPU and for how long, my comp is on usually 24/7 and my OC temps are idle around 52 and load at around 58- will this severly shorten to life of my cpu lol cause im not rich lol :(
Well your maximum load temp should be blow 60degC and the top-out for your CPU is here . Its a little hot.....but not too bad. Maybe some additional cooling is required.
If you are interested I have an excellent performing cooler for AMX XP that I bought for £35 and used for a month till I got A64. If you want it then p/m me....I'm looking for around abouts £17....so offer me!
Also see my HSF installation guide here as I have written a full guide and stuff for Socket A HSF installtion.
The spare HSF I have is the Swiftech/SilenX Combo....excellent cooler. Plus its boxed with AS5 included! :)
yeah i might actually buy it off you but i will have to get a bit of cash first how ever much 17 pounds is worth in australian dollars
That's $41 odd....we'll call it $40 and I'll research how much it costs to send...weighs a bit tho! :)
the expected life of a processor is about 8-10 years (it is infact one of the longest lived components in your computer)
overclocking with high voltages usually shortens the life of such a processor by bout 2-3 years so still it will have outlived it use way before it dies (a 486 i oced bout 9 years ago is still kikin around)
AMD Chips
Opteron Max Temp -
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/30417.pdf
A64/Sempron 754 max temps -
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/30430.pdf
Sempron 462 Max temps-
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/27375.pdf
Ath Xp max temps-
Palomino - http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/24309.pdf
Thoroughbred- http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/25175.pdf
Barton- http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26237.PDF
Intel Chips
Pentium 4-
http://developer.intel.com/design/intarch/pentium4/pentium4.htm
Xeon-
http://developer.intel.com/design/intarch/xeon/xeon.htm
Pentium m-
http://developer.intel.com/design/intarch/pentiumm/pentiumm.htm
486 lol
http://developer.intel.com/design/intarch/intel486/index.htm
note intel are remarkable cagey on temeral limits here thechips quote the maximum watts and maximim case temerature on these charts
EDIT: I FORGOT TO MENTION -- these temps are the max u can have them @ and they may only live for the length of the warrenpy on those processors personally i cut it down by @ least 10 C
You really dont want temp any higher than 55c. load, idle temp doesnt really matter, load temp is what matters more. I guess I've been lucky with my OC as to not have to run high vcore and get really good temps :)
