denali6194
I heard somewhere that if all dimms are filled that your OC suffers. Is this true?
correct oc'n works best dealing with just a single dual channel (or triple) being used. The main reason being matching sticks. Now if you bought a quad channel kit where all 4 sticks are matched then it might ignore this issue. I just know from the past whenever I added more sticks my oc would fail and I'd have to redo it
"might"...![]()
I had 4 identical sticks of mushkin but never thought to try taking two out. I'm going for 2x4G in my next build just in case
thx though
It's not so much the sticks as it is the strain on the memory controller. By adding more sticks you are using more channels.
What you say is true, but the controller does most certainly have an effect. You might be able to use two sets of memory by themselves at a high frequency, but when you add them all together the controller can no longer do those higher frequencies with all the channels populated. It's not the memory crapping out, it's the controller.
4 identical sticks is not the same as MATCHED. Matched means they were hand picked (binned) to run well with each other. This is also why there a tad more expensive to procure.
I'm running 4 sticks and haven't noticed any impact on clockability.... I'd say 4.2ghz out of a 1090T is a darn good overclock to be running stable on air 24/7.
yeah but AMD is to easy to foollol no seriously nice job. what volts is ur cpu at??? lol you just multi oc'd AMD is so much better with a FSB oc combined with multi![]()
nm I see lol ur cranking the volts on it look at my second cpu-z validation link in my sig
I see no difference between FSB mix or straight multi, bandwidth is almost identical.
I can boot in to windows just fine @ 4.4ghz under 1.5vcore as well but it's not prime stable.
