AlienALX
Well-known member
OK, so after a few weeks of letting the Ryzen launch digest I decided to do some digging this morning to see just how good it is.
The method of this is simple. First you need to go and download Blender, making sure you get the correct version for your OS (X86 32 bit or X64).
https://www.blender.org/download/
It is completely free.
Then you need the AMD Ryzen test file.
http://download.amd.com/demo/RyzenGraphic_27.blend
OK, so go ahead and install Blender. Then open the file (the .blend one) Then click on render, and Render Image (or F12).
Once the benchmark has concluded look for your time.
And a close up of mine, I got 50.25 seconds.
Now when you compare with Ryzen the magic number is between 36 and 37 seconds for a full render.
Let's see how other CPUs compare.
I am running a Xeon E5 2680 V2 8c 16t @ 3.3ghz with 16gb RAM and a Fury X.
