Tramik
I managed to get the white 3 pinned ones hooked up via a case fan controller, but I'm not sure what the best way to hook up the black 4-PIN PMW ones would be. I have a MSI X58M mobo, and I don't believe I have any spots available for four pins. Even if I did, the cable is too short to reach (they're fron panel fans). The fans are CoolMaster JetFlo 120.
I already have these ordered:http://www.amazon.ca/HDE-4-Pin-Molex-3-Pin-Cable/dp/B0081K3ZS0
Don't know if those will work though. I've been trying to find a molex connector that's 4-PIN but they've all been 3 so far, and a lot of them have a plastic casing that would stop it from fitting...
Any advice would be greatly appreciated.
