Home Server Build
k4p84
Hi all,
I have been trying out WHS on my old PC and it is working for me.
The only issue is that the pc is in all fairness to high a spec to run it 24/7.
Q6600 CPU
9800 GPU
The server is to hold all my fun media, I edit pictures and video for work as well as to hold my video and music libraries.
I will also use it to back up data from my PC and laptop.
So what do you think of the following options :
Underclock the CPU to save on the power ?
Sell the CPU and GPU and get C2D 2GHZ region and a micro ATX board with onboard GPU ?
I have looked at the embedded atom motherboard bundles but they seem to lack many sata headers.
The next question is discs. I have 2 Samsung F3 1TB discs in my main rig or do i get a pair of WD 2TB Green discs ?
I have been storing my media on a WD MY World Edition 2 NAS but I am about to hit the 2 TB size limit :-(
All help as always is appreciated.
Regards
Ed
go for a high end 939 setup, you wont be disapointed with power, or conectivity, ...plenty of both to spare, 3 gig of ram, and it'll be good
my asus has 6 SATA ports
939 was on par with the 775 if I am correct.
I just remembered speed stepping, that should reduce the power used by the Q6600 during idle times.
Maybe a board like THISwould full fill my needs
Ed
