J Jacob.xray New member Apr 27, 2012 #1 i am looking for a High RPM Red LED fan 140mm and 120mm fans that are 3 pin
Jadarite New member Apr 27, 2012 #2 [font=arial,helvetica,sans-serif]Take a look at the Silverstone 120mm Air Penetrator Red LED 1500rpm Fan (SST-AP121-RL)[/font]
WillSK Active member Apr 27, 2012 #3 From what i've seen high rpm and airflow aren't one and the same. If you're looking for high airflow there are fans that are slower and quieter that move just as much air
WillSK Active member Apr 27, 2012 #5 ah ok, then yes i think you're right then you want high rpm fans because they will provide more static pressure
