Here we go : 4200 the 3rd :D
FalconFX
Cool.... new Forum :D
Very nice idea !
Anf here we go for my first Post in it !
I bought a new HS for my 4200 (yes i finally got the other one off :D) and now heres a new Problem.
I dont seem to be "Finger Strong" Enough to push the two Plastic Thingis back throught the damn hole...
BUT wait here comes more :D
The cool HS i gought is pretty funny. Its from BFG and i normally woul trust them. On the back of the HS i Have normal GLUE !
How do i get it off... anybody an idea ? Still possible with Nail Polish "Deleting" stuff ? :D
G'day FFX
Remove the bulk of the glue with a large flat knife, and then get yourself a stanley knife blade (utility knife) and hold it fairly flat so you don't cut into the surface. Once all the visible pieces of glue have been removed, you can sand the surface with very very fine sandpaper. Make sure that the surface you are working on is flat, you don't want to rub pits into the HS. The final step is to remove the dust and rub with rubbing alchohol or thermal compound surface prep fluid. :)
yeah the holes in there are sooooo tiny and you cant realy press the two Platic Thingis.... Its pretty damn Shitty :D
humm yeah it kinda helped but heres the next prob...lol
Now the 2 Plastic Thingis wont go back through the holes.
I cant get them through there anymore... 3 persons tried it.
yes it is but i still cant get the 2 plastic thingis through the card holes. Maybe i will try buying small Screws....
Use small-nosed pliers or pincers and squeeze them together. Usually does the trick :)
maybe try snapping one of te prongs on the white things so they go in easier or just ripping them off altgether and using thermal glue instead
Here they are mate!!!!
