Yes as SieB said you will need a 360 and 240 full size rads(Phobya G-Changer, Alphacool NexXxos UT60) , you should get the ddc+ or d5 pump. And for res I will go for cylinder res cuz is much easier to bleed the air out, for example Phobya Balancer 150 or EK Multioption. And CPU block go for XSPC Raystorm or EK Supreme HF.
What case you will be using???
