Help !? Windows has stopped this device because it has reported problems. (Code 43)
SillyOldSquid
hi all,
I keep getting the "Windows has stopped this device because it has reported problems. (Code 43)" massage when I restart my pc, the message is associated with my GPU, I have two gigabyte hd 7950's 3GB in crossfire.
Why is this happening ???
How can i fix it ???
I have installed the new drivers for my GPU's also.
Check your USB cables as well, I had this error when I plugged my phone into my PC using an old dodgy USB cable.
thank you for your help but that solution isn't working and yes i did do a clean install :/
According to that link I gave you it said that windows was not loading a driver for something , were you able to find out in device manager what driver was causing problems ?
