Help watercooling my gpu
This is where the EK predator or similar would be handy. Fractal have an expandable AIO as well.
If you must keep the H100 then the AIO GPU solutions such as the NZXT G10 or Corsair Hydro may work but you'll be running out of room real fast once you have a 120mm rad and another pump on the GPU.
There could also be clearance issues depending on how much space you have between the GPU and the side panel.
So
I want to watercool only my gpu
i have corsair h100i gtx for cpu
my build is this one:
http://forum.overclock3d.net/showthread.php?t=74481
The problem is space
Can you guys give one idea?
Can you remove a drive cage to clear up some room for a pump/res combo? As far as rads go you don't really need a lot to cool a 980ti and from your build thread you seem pretty handy with tools so start looking for a spot to put in a radiator.
After looking at the build this is my main concern, the 980Ti twin Frozr is quite a narrow card and it's sitting very close to the side panel. I'd say look at the EK 980ti TF5 full cover and look at maybe an expandable AIO like the Fractal Kelvin.
125368f2-f028-4b81-b82f-e9ca8f88b614
NZXT G10 like he said, would be the cheapest way.
Expandable IAO and lose the corsair.
Any 240/280 rad custom kit for both CPU - GPU and lose the corsair.
I guess that water cooling the GPU was an after thought ?
