HELP s/pdif issues
cybermaniac
kk guys
im being a noob here most likely.
ive got a DFI LANPARTY UT NF4 SLI-DR Expert
im not sure how the hell to get the s/pdif out working.
ive set my amp to see the s/pdif coax in as the "cd" player.
and ive downloaded the newest nvidia drivers/program for the s/pdif.
im using the nvidia program atm as the realtek one seemed to suck.
im getting NO sound output whatsoever on the amp from this setup
PLEASE give me a step a step instructions on how to do this cus im just getting more and more frustrated by the minute.
Have no experience of the card, but my first poc would be to check the config/preferences util that installs with the sound drivers. Checking to see if it either needs to be turned on or un-muted or similar.
Then I enter banging head against wall stage.
what bitstream is the SpDif outputting?
for a lot of non Dolby/DTS decoders you NEED to set the mode to 2 channel and ensure digital sound is enabled ... please provide details of the amplifier/decoder
the amp is a pioneer 1016v-s
but i think the problem is on the PC......maybe its trying to output on the analogue, not on the digital
the sound card is an onboard DFI one....
i get sound on the analogue 3.5" jacks, but no out on the s/pdif
I think jumper JPS2 should be set to "2-3 On: S/PDIF-out via nForce4" if you don't have the Karajan Audio Module installed. Check the 'S/PDIF-out Settings' section in your mobo manual for a diagram.
its set to the nforce 4 jumper as default...
maybe i should try it with the ALC850 (which is the realtek one)?
Kickas amp btw
page 49 of the following menu http://www.service.pioneer-eur.com/peeservice/instrmanuals.nsf/0/96AF232D5C773E0FC12571A10023A36A/$File/ARB7359_VSX-1016V-S.pdf
explains (summary after quote, which i suggest u read first):
Other Settings
The Input Assign menu
You only need to make settings in the Input Assign menu
if you didn’t hook up your digital equipment according to
the default settings for the digital inputs, or if you have
connected equipment using component video cables.
1 Press RECEIVER on the remote control, then press
the SETUP button.
An on-screen display (OSD) appears on your TV. Use /
// and ENTER to navigate through the screens
and select menu items. Press RETURN to confirm and
exit the current menu.
2 Select ‘Input Assign’ from the System Setup menu.
Assigning the digital inputs
• Default settings:
Coaxial - 1 – DVD
Coaxial - 2 – DVR 2
Optical - 1 – DVR 1
Optical - 2 – TV
Optical - 3 – CD
You only need to do this if you didn’t hook up your digital
equipment according to the default settings for the
digital inputs (see above). This setting tells the receiver
what digital equipment is hooked up to which terminal so
the buttons on the remote correspond to what you have
hooked up.
1 Select ‘Digital Input’ from the Input Assign menu.
2 Select the number of the digital input to which
you’ve connected the digital component.
The numbers correspond with the numbers beside the
inputs on the back of the receiver.
3 Select the component that corresponds with the
one you connected to that input.
Select between DVD, TV, CD, CD-R, DVR 1, DVR 2 or
OFF.
• Use / and ENTER to do this.
• If you assign a digital input to a certain function (for
example, DVD/LD) then any digital inputs previously
assigned to that function will automatically be
switched off.
4 When you're finished, press RETURN.
You return to the Input Assign menu.
Assigning the component video inputs
• Default settings:
Component 1 – OFF
Component 2 – OFF
Component 3 – OFF
If you used component video cords to connect your video
equipment you must tell the receiver which device it is, or
else you may see the S-video or composite video input
instead of the component video signal. For more on this,
see Using the component video jacks on page 14.
1 Select ‘Component Input’ from the Input Assign
menu.
2 Select the number of the component video input to
which you’ve connected your video component.
Select between DVD, TV, DVR 1, DVR 2 or OFF.
• Make sure you have made audio connections from
the component to the corresponding inputs on the
rear of the receiver.
• If you connect any source component to the receiver
using a component video input, you should also have
your TV connected to this receiver's component video
MONITOR output (downconverting component video
is not possible after assigning an input).
System Setup
1.Surr Back System
2.Auto MCACC
3.Manual MCACC
4.Manual SP Setup
5.Input Assign
6.Other Setup
: Exit
5.Input Assign
:Return
a.Digital Input
b.Component Input
c.HDMI Input
5.Input Assign
:Return
a.Digital Input
b.Component Input
c.HDMI Input
5a.Digital Input Setup
:Finish
Coaxial - 1 DVD/LD
Coaxial - 2 [ DVR 2 ]
Optical - 1 [ DVR 1 ]
Optical - 2 [ TV/SAT ]
Optical - 3 [ CD ]
5. Input Assign
:Return
a.Digital Input
b.Component Input
c.HDMI Input
5b.Component Input
:Finish
Component - 1 DVD/LD
Component - 2 [ TV/SAT ]
Component - 3 [ DVR 1 ]
Enable your Spdif >> set ur PC to 2 channel (i assume it doesnt have DTS connect or DDL)
Inset the Coax Cable to the "Coax 2" port and select DVR as CD is your "Optical 3" port
Yeah, if there's definately no output from the S/PDIF-out port then it's worth a go. Good luck!
EDIT: I should have said try the 'via ALC850' jumper setting with Audio Module installed, but you probably know what I meant :).
yup, t'was that ALC850 jumper.
now it works a freakin beaut!
w00tness jesus buddhah allah!!!!!!!!!!!!!
you guys have no idea how happy i am :D
