HELP - Pcie second slot, for gpu?
The_Governour
I am using a X99 Strix mobo with a 5820k and a Fury X. The case that i have is the thermaltake p5, i have tried all before and it worked, now i have theis custom loop done with petg and with the riser cable then the first gpu slot is not working as its streching the riser cable.
I wont change the whole loop now and so i am wondering if i could plug the riser cable to the second pcie slot? Is there any negative impact? Would i lose fps etc??? It says in the manual that if using 1 gpu then its recomende to use the first slot.
I can either use the second slot OR order a new longer pcie riser cable.
Anyone know with the pc specs that I have mentioned if there is any loss???
Shouldn't make a difference if you use 1st or 2nd PCI-e slot, as long it's x16 I guess. One of my friends use his second slot also, because the first one fried due to water damage. He has no issues with performance drops.
