Help me design my Water Loop
FarFarAway
Hey Guys.
Well I have all my stuff:
And I have a massive case that Imma hack apart :p:
1x Zern.at Socket 939 Copper/Nickel (Rates 2nd best waterblock on market by watercoolingplanet.de)
1x XSPC Dual Crossflow 120mm Radiator with mounts (fans can be fitted both sides).
Specs
2x YS-Tec 125cfm 40db fans
1x Laing DD-12v D5 Pump (latest and greatest 12v pump on market)
1x Danger Den Fillport (for topping up your water)
3m (approx) of 1/2" ID Clearflex tubing
10x Jubilee clamps (best clamps to stop water leaks )
1x Bottle of UV Blue Dye
1x Bottle of Racing Coolant
There's a hole in the bottom for the rad and the case is on wheels so there is room for vents. I have two 120mm pretty high speed fans to push the air out of the case with :)
I was going to have the RAD + Pump at the bottom of the case ( I have 33 drives in the 3in1 device module + DVD + Floppy in the other bays). I was gonna loop the CPU straight over the GFX card from the pump and keep the PUMP loop close to the RAD. Then on the other side of the RAD I was going to put a small length of tubing, then the "T" joint and join the outflow of the CPU block to the DD Fillport
Here's a crappy pic:
Obviously the agles will be slightly diferent and the plastic tubing will be ok to bend. I haven't measured up yet or anything just need some views/alternates if you feel this is wrong :)
Thanks NoL that looks to make a lot more sense mate. I just thought the pump had to be the lowest in the system??
I'll be hooking this baby up tomorrow :)
Putting the pump before the radiator will help your temps a bit, as the pumps generally put a bit of heat into the water.
I always put my pump at the lowest point, as this way its guaranteed a constant flow of water, however it can work just as well other ways.
Oh, and one tip for you mate - DO NOT run the pump without any water in the loop ;)
name='FragTek' said:
You gonna get a waterblock for your vid card mate??
No mate I'm not. I change my vid card more often than my pants and sell the old one so I just don't see the point ;)
Cheers m8 - I won't ;)
The loop that NoL suggested looks like it would fit better in my case so I think I'll use that :)
*score for my loop design*
Ya. All this cheers mate is getting to my head.
Why not buy a maze4-gpu or the like for gpu blocks and replace the mounting with a snap in design?
Wouldn't it better to put the radiator on a side/on the top? As heat rises, wouldnt it just go back into the case at the bottom. Or are yoy having like a wind tunnel?
Edit: I mean the on the extrior or your case.
Thats what i was thinking but wouldnt it be a better idea to just have it on the top of his case with the attatched fans blowing awat from the case?
Here ya go people:
Let leak testing commence :eek:
I had to re-design the loop as NoL's suggestion would have produced (as XMS put it) a 20ft fountain!
I didn't know the pump pumps upwards! lol :o
Well done kempz. Good luck with the testing, I mean your mildy boned if it goes wrong...
Edit: Can we say boned?
Looks good kemp, great job!!!
*Crosses fingers and prays for no leaks!*
Let us know if you have any droplets in the morning :)
Buy some copper tube clips and bolt the tube for pump intake to the bottom of case so it doesnt run into ur video card.
Looks great though!
EDIT: Also get some fan filters for your rad man!
The reason I don't have a GPU block is cause I sell/swap my GPU's so often that its nice to have them with an untampered stock cooler - gets more money :)
