bought one of these yesterday, fitted no problem, and all I want to do with it is control the speed of my "koolance pmp-400" pump, I installed the software that came with it, and just cant work it out at all, so I was wondering if anyone was using any other software to control the the above , which would make things a lot easier to use, many thx monstie
Problem Solved, thought the easy way out was asking the "experts" for advice, but reverted to RTFM, and all is well, many thx again monstie
