Help! <--look here: Feser rad grill?
Flash
Alright,
1st. I am a water-cooling noob. New to this forum as well.
2nd. I need your help.
I am not sure exactly what radgrill(s) to purchase for both of my Feser 360 Radiators.
I bought the updated Feser 360 radz with the 15mm fan spacing. if that helps.... However, when I browse through the radgrill section I don't see any emphasizing Feser compatible. Which radiator grillz are Feser 360 compatible?
thnx for your help. I appreciate it.
FLASH:)
I'm pretty sure that the feser's are compatible with black ice/XSPC mounting, I didnt know about a new revision coming out though, but I'm guessing it should be the same. an ACRyan Radgrillz should be fine for your Feser's mate. Welcome to OC3D by the way!
Alex
Any XSPC/Black Ice/Aqua Computer rad grill should fit as they all have 15mm Hole Spacings.
Chances are that the descriptions for the rad grills were wrote out before the Feser rads came to the market. :)
