Heaven 4 scores
alright here are mine
4770k at 4.5, 2x 780 with a slight oc, 2133mhz dominator gt
1080p, ultra, tessellation extreme, 8xAA - like in the OP
144p, ultra, tessellation extreme, 8xAA
1440p, ultra, tessellation extreme, no AA
This is all I can get out of it at the moment.
Using +195mhz on the core, if I try overclocking the memory on the card or push the gpu any further than the +195, when running Heaven the display driver crashes no matter what I add to the voltage.
The funny thing is that it passes 3dmark Firestrike Extreme with a +210 on the core and +250 on the memory.
I think I lost the silicon lottery with these cards.
this is all i can get out of it at the moment.
Using +195mhz on the core, if i try overclocking the memory on the card or push the gpu any further than the +195, when running heaven the display driver crashes no matter what i add to the voltage.
The funny thing is that it passes 3dmark firestrike extreme with a +210 on the core and +250 on the memory.
I think i lost the silicon lottery with these cards.
1600*900...?
its 1600x900 on the version you don't pay for. You can't change it.
I'll just run the benchmark on my rig to see how a mid/low range rig scores. It'll be interesting to see how it scores when I get a new card.
Here is my low score (I'll buy the advanced version when I get paid), I've still got to redo the OC after I accidentally got rid of my original overclock when goofing around, hence why the CPU is only at 4.033ghz(stock volts).
The free version allows you to run all the different settings.
hi guys i'm running a test on a new gpu on unigine heaven benchmark 4.0 and the scores are very different
both cards are the same VTX3D HD 7870 XT LE
all i've done is just swapped the cards over and used the same setting "basic"
anyone know what's going on?
odd, are you sure they were running the same clocks or something silly like that?
