Heatsink clearance
yea im ghosts from the BFG forums. oh yea and i ordered my parts, the list can be found in the BFG hardware forum (as im on my PSP and cant list it :P) :)
because i have dual channel ram 1 stick has to go a bit further than the other and this caused a lil problem with the xp-120 but it does fit with some persuasion,if your getting a twinx kit then it will sit tight underneath the xp120 but the leds can still be seen throught the xp120 and fan.
god i cant spell for crap:eek:
cheers.
You're better off just to be safe and get some standard height RAM so you can sleep worry free at night about it fitting properly.
