Headset for Gaming and Music
iceie
Anyone knows any good headset that has a balance between gaming and music ? and does the sound make any difference when you use a sound card ?
Thanks
Well I'm using a G35 for both and the sound is fine. You can adjust the bass and treble to your desire.
Sound card doesn't change anything since it's USB, but if you use a headset that you plug directly into the sound card it would make a difference
I have a Sharkoon X-Tatic Analog, very happy with it :)
has got 4 sound card connectors:
red
black
green
pink(mic)
if you have the money, i would go for the digital version, better soud quality, but more expensive
Thanks
how much are you looking to spend ?
