Haswell or Ivy bridge
Freekill
Hey i am looking to be upgrading my cpu, mobo and ram but i'm not sure if i should get the 3770k or wait until Haswell comes out and get the latest one. What do you think?
I love how certain people class overclocking as a use of the PC :p
I'd personally go for a 3770k and Z77 motherboard now. They'll keep a relatively good resale value if you do chose to upgrade again for Haswell.
You'll be disappointed though if Haswell isn't great and you've waited that long to build a rig with it. At least if you buy now and it turns out to be good you can still upgrade, or chose not to if it's bad.
Nobody can really answer your question though, as release could be delayed, and no one knows any benchmarks yet...
I was waiting around on my old Q6600 core 2 duo rig, asking myself the same question. Upgraded to Ivy Bridge i5-3570K, Msi Power Z77, it is a great upgrade from my old socket 775 kit and well worth it, if you was running really old kit like I was.
I would say unless release is imminent then just upgrade parts when you feel the old ones are no longer meeting your needs. If your CPU is too slow now then replace it as now you have noticed it will become all the more annoying :p
I would think that haswell is going to be delayed given the competition at the moment. I would if I were Intel. Q3-4 2014 likely I would think - it will partly depend on how quickly intel want to release for the mobile market.
In any case - the focus will be on power consumption and performance per Watt, not raw performance. I'd expect to slightly slightly better performance than IB but much lower TDP. I'd upgrade now :D
upgrade now...
go and get yourself a nice 3770k and a msi z77 board some corsair vengeance ram and you´re sorted :)
Personally I dont have the patience to wait for Haswell. I want more shpeeeeed noww!!!!! I'm still on an AMD Athlon X2 @3Ghz and its ticking me off. need more powa!! It's kiling me to have to wait another week to buy the 3570k :(
Normally my rule is to never wait cause they're will always be something newer, better and cheaper coming out right around the corner. But in this instance, I say wait.
Haswell is supposed to start production late on Q4 of 2012 which is right about now and be out for retail around Q2 of 2013. That's not that long a wait.
Now the main reason I say wait is the rumor that just sprung up that the next generation, Broadwell, wont be available to buy separately and will only be available soldered to the motherboard. Desktop CPU's for that generation will be stepped up Haswell procs which likely means they'll still work on Haswell socket motherboards and that means you can keep your Haswell rig a generation longer. Drop one of the refreshed Haswell chips in your rig in 2014 and you've got a lot more life without have to swap in a whole new mobo and OS and all that.
Now all that said, it ultimately comes down to what you're running now. If you're on a AM2 dual core then you might as well jump now but if you've got something solid like a i7-920 or even Core 2 Quad, then it might be worth it to stick it out a little longer at least until we get a little more info on those Boradwell rumors.
Right now i'm running a phenom 2 x4 but it is a big bottleneck for my 7950. I've been setting up for a big upgrade for a while now just not sure if waiting would be worth it.
A Phenom II X4 isn't a bottleneck for a 7950, not a single one anyway especially if you've got it overclocked. I say wait around a little and see what the word on Haswell and Broadwell gets out there a little more.
I'm not even on a Phenom, which is why I anxiously await my new parts. Next Thursday 3570k, you are MINE!! Muuuwaaaahahahahahahahaha :D
