Will the RX360 radiator with fans fit in the top of the HAF X? I read on other forums that there were clearance issues with the motherboard tho. hoping for some feedback from some of you guys who have put a RX360 in the HAF X.
update/
I was googling around about the haf x, seeing if it could fit a RX360. I saw that it could, and almost bought the case, before realising that I wasn't sure if the mounts in the top (200mm fans) could fit 3 120mm fans.
I saw on another thread that people had trouble routing the cables for the IO after trying to fit a 200mm fan. So I'm just putting this out there, to see if anyone has tried to fit 3 120mm fans into the top panel of the HAF X.
Thanks in advance
P.S. feel free to tell me if there are any other suitable cases in the same price point. I've been having trouble finding a case
update/
Thanks in advance
