H80i Pump Problem
cameron2134
So a couple days ago I got myself a H80i. I managed to install it correctly with both stock fans in push pull config, and it's been working perfectly fine for 2 days. However, this morning I power on my system, and notice that the fans are louder than normal, so I open up HWMonitor and notice the CPU (i5 3570k) is hanging around 60-70 degrees on idle instead of it's normal 30 degrees (still on stock speeds - was actually going to overclock today, luckily I noticed this problem!).
I then opened up Corsair Link and noticed that the pump RPM was sitting at 0. I thought it was maybe just a one time thing so I restarted my system, and the problem remained. I havn't remounted the pump yet but I tried a different power connector to see if that was the problem and it still persists.
Also, the LED does light up, until I open corsair link it seems to slowly fade from red to nothing (which I'm not sure if it's ment to do) but so far it's looking like the pump has died. Anyone else got any other suggestions? Going to reseat the pump and see if that has any effect, although so far it looks as if the pump has died but it's worth a try anyway. Thanks in advance.
