Glassjaw003
I understand the difference in performance between the H80i and the new H60, but I am willing to forgo a bit of performance for aesthetics. Now I'm sure I could chuck a H100i in there with a bit of modding, but I don't think it would look good.
Here are two pictures of where the cooler would be going. The H60 would be much thinner than the H80i, which is my worry because I may not want something so bulky in this particular spot.
So I thought I'd ask the forum, maybe you guys and gals can give me a good opinions.
The cord will be moved when I get the PSU in.
I took a close shot of where the fan mounts so you could tell the thickness of everything. I know when I install either cooler that I will need to move the light bar, but I might just push it up further.
Don't mind the stock cooler, only in there because the CM v8 pushes on the window and I have no clue where to find semi threaded rods in metric, hell I can't even find them in fully threaded form, to extend the side panels outward.
I've also looked into getting a silent CPU cooler, but I can't fit my ideal Ram.
