H80i/CorsairLink frustration
jimbo
I recently bought a H80i and finally got the thing in yesterday.
The problems I'm having are as follows:
a) the cooling performance is rubbish (on my unit). When playing Far Cry 3, I hit low 60s when the core clock as at stock. That's the same performance I got with the Intel reference cooler.
b) I installed Corsair Link 2 and was equally as disappointed. There is no option to change the LED colour nor can I adjust the fan or pump speed. I have checked ny cabling THREE times and I have installed it exactly as the manual instructed.
It is also telling me that my HDD is over 100 degrees. Epic fail.
I cannot update the firmware because Corsair have removed it from their website.
If anyone could help me, I'd REALLY appreciate it.
Thanks in advance.
google the corsair link versian 2 beta uninstal the original and restart your pc then put the beta on then add the usb firm ware
I got my H80i last week
50° under load at 4.0 GHz, Corsair Link works fine, can adjust everything
Did you use the pre-applied thermal paste or did you buy some thermal paste?
I used the pre applied stuff. I am going to get some MX-4 right now.
I just did a burn test and at 4.2GHz, I was hitting 78 degrees.
What a joke.
What a joke.
maybe a bad unit? either you screwed up on the mounting or the unit is bad.
/edit
way 500 posts, now i'm part of the crew!
/edit
Congrats on your 500th post!
I checked the mounting twice now and everything was nice and secure and i got decent contact with the TIM on the cold plate, from what I can see.
I know IB runs hotter than SB.
i had a 3570k a few days ago with an h60i and 2 corsair sp120QE at 4.2ghz. i never hit 60°C.
I am thinking that the cold plate hasn't made adequate contact with the IHS on the CPU. I purchased some Arctic Cooling MX-4 last night and I'll give that a go. Hopefully it helps greatly!
Thank you all for your replies!
