H100i or H110, Best performer ?
Dicehunter
Resident Newb
How much better is the performance of an H110 compared to an H100i ?
Does it warrant a change in hardware ?
Thought I better refer you to this before the gov comes and tells you to read reviews!
Personally I think the H100i is capable enough and the best looking of the 3 and for that reason i'd go for it if I was buying new again or stick with it if I had it. While the added rad space of the H110 is nice there is still no pretty SP140 and the pump is a bit lame looking if you ask me. Then again perhaps the asetek reliability is worth it over the temperamental CoolIT solution.
JR
Thanks for the reply, But I've already watched the review and I'm looking for feedback from users who have used both the H100i and H110 for an extended period of time and wondering if the performance difference is worth the sacrifice of the customization of the H100i i.e LED's and software and general looks of the unit.
Only you can answer that. I personally like 120mm fans so a 110 wouldnt be an option - the rest is down to you.
Think I'll keep hold of my H100i, I've got my XSPC kit ready and waiting to go but I'm moving yet again in less than 2 months so I might as well wait until I get settled again to install it :)
Ive sent fully watercooled rigs in the post without hose clamps - build a rig right and you dont need to worry about moving it.....
True but I'm moving with the help of a friend and he drives like he has full body tourettes so I'm more than happy to wait ^_^
