H100 LED Change?
Metalboz
This may be a daft question as i know the H100 is a sealed unit but does anyone know if it is possible to change the LED inside the digital fan control unit to a different colour one?
that part is accessible but will void warranty so caution needs to be used. you wont run into the liquid part so ur safe.
Do you know if it is a generic LED inside and easy to change?
I want to change the colour from white to red nut if it is too much of a pain then i will leave it
will just use a coloured sweet wrapper then
