Here is how to get your dual core AMD system running like it should with no hitches and stibility issues..............since the new AMD DUAL CORE OPTIMIZER came out people say you dont need the MS HOTFIX anymore, i dont know if this is true or not, but i tested these fixes with and without one another, and found they work better together, giving an increase in performance.....but thats from my personal expierience......try for yourself, i recomend installing both the MS HOTFIX and the AMD DUAL CORE OPTIMIZER, as they work good together and also give a performance increase by about 1-5%.
name='Kempez said:If you read[/B'] the guide it goes through the whole thing and gets you to install the patch and then the Optimiser![]()
name='XMS' said:I just wish there was a fix for my rig being slow as hell in some gamesNothing seems to work.
zachig said:Is it a known problem, because I've never heard about Intel Dual-Cored CPUs problem, or is it just a problem in your specific rig?
What "slow-down" do you get, in FPS? and on which games? Maybe you should "google" for some "Video/Graphics" optimizations for a specific game where you encounter these slow-downs...![]()
XMS said:Its just in Counter Strike to be honest. More than 5 ppl on the screen makes the fps drop down to 30, and it just laggs like mad.
I've searched for answers but not turned up much.
Other games that are more graphics intensive work fine :/
zachig said:If I'll find anything useful I'll let ya know...![]()
name='XMS' said:Cool thanks. I'm changing motherboard/processor soon so hopefully that will get rid of it. The strange thing is, that even reducing detail and AA/AF settings does not reduce the lag - its almost like its programmed in - ol
name='mrapoc' said:iv eheard dual core (such as x2 3800 for example) is not supported on windows xp home?!?!? i hope this patch fixes that!
zachig said:Yeah, that's bul***t, I don't know who told you that and/or where did you hear it from, but don't worry...Windows XP Home FULLY supports the Dual-Core, as well as ALL other Win XP versions...![]()
I guess it'll be the same for the Vista...![]()
