T
Thickbrit
Guest
Just wanted to let u all know,i got my GT going now.I had a few problems at first.I messed up my vagp mod,luckily it didn't fry,then i got dc4 where the seal-string goes,tried to clean it off with IPA which made a mess of my conformal coat,stripped it clean,start again.Reapplied the coating,totally filled the cpu socket with dc4 and squished it throught the pin-holes.Installed chip and new fitting kit,then put an extra bead of string around all 3 joints.Fired it up,but i still had contact problems with all the washers on the screws.To be brief,i had to sand about 1mm off the front covers legs,then it fouled a component,so i had to notch out a slot for that to clear.By now i'm getting a bit fed up,so i was well pleased when i next fired it up and it all seemed good,and still does......
except for the fact that i installed the wrong 2.4,and have got to do it all again........sigh
