Great product
Volt
Hi all.
Just want to say thanks to everyone here in the forums who helped me get this up and running. I love not having to worry about CPU temps anymore. I'll recommend a prommy to anyone.
Couple of questions though.
Is the temp readout on the LCD your actual CPU temp? Just wondering because many people are having issues with high board temps, me included. For some reason the P5W has it's temp sensor near the SB area. Anywhere between 45 and 50 degrees F. Just want to make sure my CPU is being cooled properly.
The other issue was partly answered in another thread, but is there any timeframe on Windows x64 support or software?
Nope, that's not the CPU temp but the Evap temp.
The best way to get a good reading is to actually mount a probe on/by the CPU itself...
...some crazy people around here have actually cut away the IHS and put one in there :O
PS: NICE looking system! :D
I'll have to look into an LCD kit that can monitor my temps then. Thanks for the advice.
name='phil123' said:
uv dye is a nice colour!
I used that Fluid XP Extreme. I'm happy with the way it turned out.:) I'd read where the blue UV didn't show up as well as the green, but this seems to have worked out OK.
