Hi I have building a new rig 90% gaming 10%working ( rendering , streaming , etc ) Rig Spec is 3700x , ASUS ROG STRIX AMD Ryzen X470 , G.skill DDR4-3800MHz 16gb running 3600 tighten timings etc with a 1 TB M.2 with a 4k monitor but when it come to buy a Graphic Card well i have no idea what to buy i have around 750 pounds to spend and the amount of Graphic Cards in that range is alot and i do not care if it is team green or red are used or new. i just do not know should i buy a gtx 1080ti or RTX 2080 super are something between as long as it is a 2 slot card max . Thank you for many and all help .
