I would probably avoid it as I'm not 100% sure that it is a reference design card. Also as the cooler in the Iceq4 is quite different to that of a stock cooler, the fan speed profile from another card might not be suitable.
If you want to push the card further then I would suggest that you ramp up the cards fan. You can set it to run at different speeds depending on its heat output.
Would anybody suggest me something better than RivaTuner? I mean, it is very irritating for me under windows 7, when every time I boot into windows, a Warning appears whether to allow it at windows startup or not? Isn't there a fix for that?
