GPU's worth Boints
8bitbreed
I'm trying to compile a list of gpus worth benching for boints. I'm looking to bye as many as i can on Ebay, so i don't really wont to spend more than 80-100 on each card, exsept for the x2's
so far:
3850/3870 + x2
4870/4890 + x2
8800gtx
GTS250
Any suggestions would be great.
you need a fast sandybridge cpu (at least) to get good boints from gpu benching mate, their speed in the older tests is insane.
all 8800s are ok, 8600 isnt bad 9800gtx+ and gx2, 260 216, 280, 285, 460, 480 from nv with the 5770, 5870 5850s being good with those you named too
Thanks, thats quite a shopping list i have know.
8800 series (G80)
20 hardware points in all the tests if you run the card with cold air. All they need is a simple vmod and OCP mod that takes 2 min to make.
All 8800 series card are the same.
They only made the reference pcb so all the mods are the same the only real diference is that some 8800GTS 640 mb cards used a new version (A3) of the G80 chip that overclocked sligtly better.
Ok ill bye the cheapest one then, can you help me out with the modding when the time comes, or do you have a link to a good thread. thanks
