GPU Waterblock compatibility
dujames777
I have a full XSPC waterblock for a reference 780ti, will this fit on a 980ti? Also, will a reference 980 waterblock fit a reference 980ti?:confused:
Check XSPC for compatibility, but i dont think it will. 980 reference should fit on a 980ti though. Again, check and be sure.
No. A reference 780Ti will fit the reference 780, Titan and Titan Black. A reference 980 will also fit some 970's based on the same PCB, not all. A reference Titan X block will fit a reference 980Ti, the Titan X was released first so most are named after that.
JR
