Gpu to pair with a Amd X4 880K
Rob_the_scot
I want to do a Amd matx build I have picked most the parts and will use some older parts I have sitting about
What I have picked
Amd X4 880k
ASRock A88M-G/3.1 has m.2 :D
128gb m.2 for os ....might get larger depends on the dough
I already have 2 sticks of 1600mhz ram
and sfx silverstone 450 gold rated psu
Now all this leaves is what GPU to get I want to stay with amd any inputs on what I should get?
No other drives will be fitted to the pc, as for the cooler unsure prob wont be over clocking if I do just a small over clock
Gaming will be done at 1080p at 60 hertz than later hooked to a tv that is also 1080p
What I have picked
Amd X4 880k
What is your budget for the GPU?
Any reason why it need to be AMD
Alternatively you can try ebay and you could get an old R9 290 or 290X.
they are very over priced atm on the bay although i've seen a couple of Vapor X on there but my bank balance is saying Noooooo :p
