Yeah, if you look at the placement of the screwholes vs memory chips it seems pretty dead on?
why would you want a TX cooler? they are exactly the same.
Cause it's all black and you don't loose warranty. But yes, it will have the wrong branding on it.
That's an EKWB backplate that comes with the water blocks.
You could have a look at Coldzero though, or make your own![]()
Yah I know that and was unsure wether they only came with the waterblocks or were actually sold seperately.
Coldzero, will check that out, thanks. Not sure about the make your own though![]()
Those backplates are sold separately, but they're meant to be used with the blocks though. Coldzero does some fine work, I got a backplate from them for my xonar phoebus, and I must say it's one sexy thing
About the warranty, is it not voided from the moment you remove the stock cooler? There's a sticker on one of the 4 screws around the gpu dye which presumably voids warranty if broken. I guess for evga it doesn't matter as long as you mount/ship the stock cooler when rma'ing. Asus, however.. Well you know..
Well he won't have to replace the entire heatsink though, just the shroud that goes over the top.
