EazzyTarget
Hey guys, first post here... been reading a bit and think I've done okay so far with my parts... but wondered if the parallel path through my GPU blocks is going the wrong way.
I've designed and put together most of the following water cooling in my Cosmos 1000 case:
Resevoir
Pump
CPU
Rad 1 (Black Ice GT-XFlow 120)
T-Splitter
2x8800 Ultra GPU's in Parallel
T-Splitter
Rad 2 (Black Ice Pro 3)
My concern, from my reading, is that the Swiftec Stealth GPU blocks in parallel may have different pressures and that the water would circulate through one more than the other... creating a temerature problem in the one with less flow.
How are you guys handling 2xSLI (or more) in your cooling loops?
-EazzyTarget
Resevoir
Pump
CPU
T-Splitter
T-Splitter
-EazzyTarget
