First off, Hi to all!
I have a small dilemna that I hope some of you guys can help me out with, I've decided that I want Water Cooling for my graphics card, but in all honesty I know nothing at all about what a good water cooling set-up would be.
I'm gonna be using a Mach2 for my cpu so what I really need is a set-up that would be fine for cooling just one GPU with the option to install a second GPU block should I decide to go for SLi or Crossfire at a later date. I'm not all that bothered about cooling the Motherboard chipset as it never really gets that hot and I understand that fitting a block on the DFi NF4 chipset can be problematic due to the proximity of the Graphics cards and probably wouldn't raise performance significantly anyway.
I'd prefer to start out with the very best set-up possible as I'd rather not buy a low-end kit only to realise that I'd have been better off spending a little more and getting the right stuff from the get go. So, really what I'm asking is what stuff in the opinion of you guys would be best for what I have in mind?
Thanks in advance,
JAFFA
Thanks in advance,
JAFFA
