Good Old X58 Rig
RizeAllard
Greetings to all!:)
At the moment this is my main rig. That was the one I learn how to create custom loop first. There was a lot of modifications in that loop. Almost everything has been changed since I started to build it. Now this is the current one, but I did not finished it yet. But i will finish it when I change to x99 system. :)
The current specs of the rig is:
CPU: Intel Core i7-950 was clocked to 4.17 GHz but now im using it in stock to prevent it for my sister or my father who will inherit it...:)
Mobo: Gigabyte GA-X58A-UD7 Rev 2.0
GPU: Gigabyte GV-R929XD5-4GD-B (R9 290X)
Memory: A-DATA XPG GAMING Rev 2. DDR3-2000MHz CL10
PSU: Chieftec CFT-850G-DF 850W Modular
SSD: OCZ Vertex 4 128GB
HDD: 3× WD Green 2TB, 1× Seagate Barracuda 1TB, 1× Hitachi Deskstar 1TB, 1× WD Green 1TB
Case: Thermaltake Speedo Advanced
Watel cooling loop: EK Supreme HF cpu block, EK FullCover R290X block with backplate, XSPC 750 H2O Res & Pump combo, EK XT240 Rad, and XSPC RX120
Fans: 2× BeQuiet! Shadow Wing 140MM PWM front intake
3× BeQuiet! Shadow Wing 120MM PWM back radiator an radiator at the top,
2 Thermaltake 120MM TurboFan one as back side intake and one as for controlling inside airflow
1 Thermaltake 230MM Side panel intake
The inside of the case in daylight:
Turned off:
Turned on:
Closer look:
The rig at night with full bright :)
a bit closer:
And the cable managemant:
