Good fan scan stocks?
mrapoc
From http://www.scan.co.uk/Index.aspx?NT=1-0-8-244-0
I'm probably getting a Scout Storm case and want two 120mm fans on the side window for even more cooling :)
As the air passing through the side window may produce a bit more noise than normal the fans going in there need to be top notch in terms of quietness not to add to the overall system noise - but still push air :)
I'm hoping the other three stock fans are ok (2 x 140mm and 1x 120mm) so looking at just two 120mms for now
There was a fairly comprehensive review of just about every fan on the market atm in CPC's latest issue.
in 120mm the best came out as the
Sharkoon silent eagle 1000. ( Scan )
next nearest was the
scythe gentle typhoon D1225c ( quietPC )
I just got the Silent Eagles, and I am very happy with the sound but they don't push much air, good if your PC doesn't have very hot components though
+1 for the noctua fans i have them all in my antec 900 and ive never looked back,ive had some xigmatek fans in the past and some of the sharkoon ones and they are nothing compaired to the noctua they are just amazing hence the nice pricetag just my 2cnts
Seem to be nosier than the silent eagle in reviews though?
ive not tried the newest silent eagles from sharkoon,but they wont push as much air as the noctua's and ive only ever nown noctua not to overstate there cfm ratings or DB ratings
i mean 18db for 56cfm of air is pritty good dont you think plus the U.L.N.A and the L.N.A
that is a good kind slient eagles
