If you've grown weary of mice that have dozens of buttons and weigh a ton, the Glorious Forge Golden Panda is the perfect mouse for you.
Glorious Forge Pro Golden Panda Wireless Review
I quite like the look of this, Nice and simple clean design... Although I'd prefer a wired option as I'm not too fond of batteries in my mice/keyboards as they all inevitably retain less and less charge over time.
Never understood where the cost comes in for these overly simplified mice. Its nice and sleek but £100 for this??? The naga mmo mouse is the same price and has better justification for its extended button options and versatility.
And as Dice mentioned, wireless with batteries? thats a massive no in 2023. Id expect this from the 2000-2010 era.
So what exactly are you referring to wireless being powered with, if not a battery? Solar panels? :lol:
Good point. I actually misread into about the battery thinking its the old method of AA/AAA. I was about to answer that typical lithium would be better, but its already using it. Friday brain shut down mode.
But you know there are many methods that could drop the battery method right?
Kinetic via electro generator,
Inductive charging
Resonant (magnetic) charging (slightly inefficient)
I think we already have mouse pads that charge the mouse inductively, but its limited to one small patch.
If they want to use batteries they should make replacements readily available and easy to replace, It's the main reason I don't own any wireless products, Battery degradation and nigh on all wireless products are built in a way that you cannot replace degraded batteries or even buy said batteries.
With all this wireless and battery talk, I love my Logitech G Pro mouse. Best mouse I've ever used. The battery has lasted me over a month of use before getting down to 30%. I will say however I turn the rgb lights down low to extend life. No need for them.
When you are done with the PC, plug in mouse, let charge for 60 minutes, it's full. Next time you come back unplug and enjoy wireless. I see 0 reason to get a wired mouse these days(not comparing to cheap mice). The benefits of no drag from the wire I cannot understate enough how much of a difference it made to me. That and the speed being identical to wired, makes it worth it.
Not wired at all. During use it's not wired. You plug in once a month if not less depending how often you use it. That's hardly wired.
If you have a charging while in use mouse with a pad, cool. Hardly an advantage imo
A month I wouldn’t say, that’s down to you have lowered the RGB lights basically. Without doing that, it wouldn’t last more than a week. Have a friend who tested this.
There's no reason to run it full tilt though and more than likely with static mode (using breathing where it turns on and off also extendeds life). Regardless even if you did, plugging it in takes 3 seconds, unplugging takes 1. 4 seconds a week of wired I would not considered it to be a "wired" mouse. When it's wired it's not in use. If you use it will it's charging exclusively then sure it makes no sense to purchase such a device.
There's really no good argument against modern wireless higher end mice. Batteries last long(generally), they are as fast in response, and no cord to get tangled or create drag while moving your hand.
In regards to charging pads, afaik they don't work to well while you use the mouse but obviously it charges while not in use. That's the next logical upgrade over say a G Pro, but I don't consider a 4 second inconvenience to be a massive downgrade.
I got nothing against wired mice and I still own plenty of them and use them, just not for gaming.
