Glock's small upgrade project
glocktodahead
Hey I am looking to upgrade my case, power supply and HSF. Here are my system specs right now:
Asus A8N-SLI Deluxe
AMD 3500+ Venice stock @ 2.2
BFG 7800 GTX 256mb
Samsung M3 2.0 GB RAM
Onboard audio
480Watt cheap psu
Here's what I think i've made my mind up for:
Case:
ThermalTake Tsunami Series Aluminum ATX Mid-Tower Case with Clear Side, Top USB, Firewire and Audio Ports – Black $139.99 + shipping
http://www.tigerdirect.ca/applications/SearchTools/itemdetails.asp?EdpNo=1010723&Tab=11&NoMapp=0
Power Supply: Enermax / 600-Watt / ATX / Dual 80mm Fan / 24-Pin / Dual PCI-Express / SATA-Ready / Power Supply / SLI Ready
Price:
$194.99 + shipping
http://www.tigerdirect.ca/applications/SearchTools/itemdetails.asp?EdpNo=1419091&Tab=11&NoMapp=0
I haven't made my mind up on the HSF I was thinking about the XP-120 but I don't want to have any issues with fitting. I am trying to get as much cooling as possible in my Case so that I can overclock my cpu and to get rid of the arifacts that I am seeing with my gpu. (I notice that while I'm playing a game it gets really hot in my case right now) I think that the load was around 61 C and higher.
any conflicts with my thinking so far? any suggestions? and which HSF do you suggest?
I wouldn't get the Tsunami case. I've used them a few times in mates PC's and the quality is pretty poor in all honestly. What about an Antec P180 or a Silverstone case?
PSU is decent but dear and I would go with a thermaltake Big Typhoon :)
Tsunami :(
i had a tsunami and it wasnt that bad but it was the first case i ever got lol... but now i cant stand the thing. the tooless pci brackets are so naff :mad: .... that was the worst bit.
custom pc mag reckon that artic cooling freezer 7 pro is the way to go for cooling intel -19 more than the standerd HSF and its quiet aswell. look into it :) :wavey:
Cooling giants are the TT BT, Scythe Ninja, Noctua U-12 (not sure bout this one), and Tuniq Tower. Only one we have from experience is the BT (by me :p) though... We really need to get our hands on the others for review :D
I'm so glad that I came here before purchasing lol. I will look into a different case. I will also look at the other hsf and the power supply u said was decent....are there any others kemp that are around the same or a little over the price that you would recommend instead?
I'll read over your BT review again WC
EDIT: it looks as though to use the BT I will need enough room in my case. I looked at the Antec P180 and it looks like it could keep my components nice and cool. I was hoping to get a case with a window, but I don't want to have to sacrifice performance. If I did go in with the Antec case I would have to make sure the BT fit because there is no way I would cut a hole in it lol.
K I have been looking at the P180 for like 30 minutes now and its selling for $141 CAD so I think I might pick it up
Thank you for your help. So this is what im certain I will pick up:
The antec P180 case
PC P+P Turbo-Cool 510 Express / SLI power supply
and now for the hsf..
