Given a choice, what would you pick?
K404
Tonight, to settle a "what would win" question i've been asking myself, i'm going to be benching SPi 32M at 400x9, with the following RAM setups:
1:1- 400MHz 3-3-3
4:5- 500MHz 4-4-4
2:3- 600MHz 5-5-5
Which one do you guys think will give me the best time?
straps will be the same for all, subtimings will be too I reckon. I wont be playing any fancy tricks.
K
LOL theres other options, that might well work out better e.g. 450x8 with 450Mhz or 562MHz RAM or, yea- 600MHz 4-4-4...humour me!
Another question (which I wont answer tonight) is:
say 556x9 RAM options are: 556MHz @ 4-4-3 or 667MHz @ 5-5-4...which will give the better result?
Enough of that for now though...back to the original post! :D
Option 2 or 3.... I think 3 is going to give you a slight advantage, I don't think the slacked timings can make up for the 100mhz increase.
I'd go for opyion 3 cos DDR3 is already showing it can just about match or beat DDR2 purely on speed despite much higher latencies!
