cybermaniac
hey guyz
try this out:
if u want to play a game and want a save a bit of ram and processor power, try this:
make a batch file called stopservices.bat and put this into it:
and then make a batch file called startservices.bat and all this does it start the services that u stopped earlier:
hope that helps sum1........feel free to add to this post with helpful services to stop for gaming and/or other things/commands to stop/start other things
try this out:
Code:
:: A "batch file" that stops unnecessary services to maximize performance of an XP pc while playing internet games.
:: ***Note*** Some services may or may not be necessary for your particualar configuration.
:: For a detailed descriptions of XP services that may be stopped visit [url]http://www.tweakhound.com/xp/xptweaks/supertweaks6.htm[/url]
:: The "::" leave room for definitions of each command.
:: Change directory to root.
cd\
:: Turns off excessive display while the batch file runs.
echo off
echo .
echo .
echo .
echo ..
echo ...
echo Stopping Services
echo ...
echo ..
echo .
echo .
echo .
:: Enables ClipBook Viewer to store information and share it with remote computers. If the service is stopped, ClipBook Viewer will not be able to share information with remote computers. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop ClipSrv
:: System Event Notification - Tracks system events such as Windows logon, network, and power events. Notifies COM+ Event System subscribers of these events.
net stop SENS
:: Com+ Event System - Supports System Event Notification Service (SENS), which provides automatic distribution of events to subscribing Component Object Model (COM) components. If the service is stopped, SENS will close and will not be able to provide logon and logoff notifications. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop EventSystem
:: Computer Browser - Maintains an updated list of computers on the network and supplies this list to computers designated as browsers. If this service is stopped, this list will not be updated or maintained. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop Browser
:: Cryptographic Services - Provides three management services: Catalog Database Service, which confirms the signatures of Windows files; Protected Root Service, which adds and removes Trusted Root Certification Authority certificates from this computer; and Key Service, which helps enroll this computer for certificates. If this service is stopped, these management services will not function properly. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop CryptSvc
:: Help and Support - Enables Help and Support Center to run on this computer. If this service is stopped, Help and Support Center will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop helpsvc
:: Indexing Service - Indexes contents and properties of files on local and remote computers; provides rapid access to files through flexible querying language.
net stop cisvc
:: IPSEC Services - Manages IP security policy and starts the ISAKMP/Oakley (IKE) and the IP security driver.
net stop PolicyAgent
:: IPv6 Internet Connection Firewall - Provides intrusion prevention service for a home or small office network.
:: net stop ip6FwHlp
:: Logical Disk Manager - Detects and monitors new hard disk drives and sends disk volume information to Logical Disk Manager Administrative Service for configuration. If this service is stopped, dynamic disk status and configuration information may become out of date. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop dmserver
:: Net Logon - Supports pass-through authentication of account logon events for computers in a domain.
:: net stop netlogon
:: Server - Supports file, print, and named-pipe sharing over the network for this computer. If this service is stopped, these functions will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop lanmanserver
:: System Restore Service - Performs system restore functions. To stop service, turn off System Restore from the System Restore tab in My Computer->Properties
net stop srservice
:: Task Scheduler - Enables a user to configure and schedule automated tasks on this computer. If this service is stopped, these tasks will not be run at their scheduled times. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop schedule
:: Themes - Provides user experience theme management.
net stop Themes
:: Universal Plug and Play Device Host - Provides support to host Universal Plug and Play devices.
net stop upnphost
:: Workstation - Creates and maintains client network connections to remote servers. If this service is stopped, these connections will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start.
net stop Workstation
:: Event Log - Enables event log messages issued by Windows-based programs and components to be viewed in Event Viewer. This service cannot be stopped.
net stop Eventlog
:: Plug n Play - Enables a computer to recognize and adapt to hardware changes with little or no user input. Stopping or disabling this service will result in system instability.
net stop PlugPlay
echo .
echo .
echo .
echo ..
echo ...
echo Services Stopped
echo ...
echo ..
echo .
echo .
echo .
exit
Code:
:: The "::" comments out lines so that they are not run.
cd\
:: Turns off excessive display of from the batch file.
echo off
echo .
echo .
echo .
echo ..
echo ...
echo Starting Services
echo ...
echo ..
echo .
echo .
echo .
net start wuauserv
net start SENS
net start EventSystem
net start ClipSrv
net start Browser
net start CryptSvc
net start helpsvc
net start PolicyAgent
:: net start ip6FwHlp
net start dmserver
:: net start netlogon
net start lanmanserver
net start srservice
net start TermService
net start Themes
net start upnphost
net start Workstation
net start Eventlog
net start PlugPlay
echo .
echo .
echo .
echo ..
echo ...
echo Services Started
echo ...
echo ..
echo .
echo .
echo .
exit
