Gaming laptop (suggestions)
Rob_the_scot
I am saving up for a gaming laptop I have been looking at the 13 inch models on scan and pc specialist,
I have been looking at the i5 duel core models with HT,
Is there any laptops for gaming I should look at have been searching for amd apu ones but nothing really popping up.
Only thing I do want is hdmi out put so I can hook to my 22inch 1080p monitor
size well 13inch is perfect might go a bit bigger
I have spare ssds so not bothered about storage options just as long as I can replace it
No need for optical I have an external one
performance well as long as I can play alien isolation even on low and its smooth than I'm happy In other words no need for duel gpus or gtx 890m ect ect
Budget max ill spend is £800
