D dumo New member Nov 10, 2006 #1 For its size, surprisingly ....pretty light comparo to 1950XTX Few inches longer than P5W64...
P Phil Stanbridge New member Nov 10, 2006 #3 They are exceptionally nice cards arent they. Nice set of results!
S stocky New member Nov 10, 2006 #4 Very big and powerful! I spy two plugs and two SLI fingers. Are there two fingers so that it is possible to run four in SLI? If this is true, then that would require the PSU to have 8 PCI plugs :O
P Phil Stanbridge New member Nov 10, 2006 #6 You have to use 2 pcie adapters per card - and you can use up to 2 cards, hence the Quad SLI power supplies doing the rounds (they come with 4 x pcie adapters).
A advancedkill New member Nov 10, 2006 #7 Yes, but will be half a year at least before we see some actually good drivers, where none of the top games experience "problems.. . "
M Mr Dizzy New member Nov 10, 2006 #8 nice score from stock just got some of these too and this was a first run of 3D 06 cards r at stock 575/900 cpu OC to 3.7
M maverik-sg1 New member Nov 10, 2006 #9 Impressive Dizzy and Dumo - Thanks for sharing, keep us informed pls. Mav
S sacha35 New member Nov 10, 2006 #11 Very nice results, will be nice to see some overclocked results from that beast.
D dumo New member Nov 11, 2006 #12 So much (oc) fun...With This card Heres @ 666/1020... http://service.futuremark.com/compare?3dm05=2321406
B bazx New member Nov 11, 2006 #13 dumo do these cards have the same ddr3 as the 79gtx or could you show on of the chips s/n number thanks baz
M Master_G New member Nov 11, 2006 #14 Card is so light compared with ATI as the cooler is almost all aluminium whereas the ATI cooler used a lot more copper. Great results, thanks for sharing Dumo, those are numbers i can only dream of at the moment! G
