http://www.steampowered.com/v/index.php?area=news&id=851&cc=--
Just so you all know, it seems valve have just released another one of their amazing updates. This particular one stops servers forcing the above command to be set by the server. Therefore, if you haven't already, I'd advise you to put the following command into you config.cfg on your client:
cl_restrict_server_commands 0
The OC3D (and hexus
) server had a plugin to force this, but it won't work anymore now, so in order for pretty much all server plugins/mods (mani, gunmod, deathmatch etc etc) to work on your client, you'll need to change the command from default. It would be a good idea to do so, because some plugins won't let you join the server unless you've change it.
Added protection against servers manipulating the cl_restrict_server_commands cvar
The OC3D (and hexus
